Página 1 de 13 1234567811 ... ÚltimoÚltimo
Resultados 1 al 10 de 129
Tema: Bmw G650 X
    Foro Adicto Avatar de Mr.Thompson
    09 Jan 2006
    KTM 950 SE
    al lado del TGV
    Bmw G650 X
    Se ve muy pequeñita pero la Hard Enduro tiene buena pinta.
    17 Jul 2006
    KTM 1190
    Ontinyent (Valencia)
    Jooer, me encanta la supermotard. Tiene muy buena pinta. El único defecto que le veo es el escape muy cerca del asiento...
    Este es mi Foro Avatar de PEM
    R 1200 GS Adv.
    En mi casa
    Pos a mi todo lo que tenga menos de 100 cv no me gusta, y preveo que este artefacto no va a llegar,
    Este es mi Foro Avatar de ayois_bandit
    26 Jan 2006
    gs650f dakariza
    Malaga
    Parece una japonesa... no me gusta. ea!!!
    17 Jul 2006
    KTM 1190
    Pues a mi, si sacara 60 cv y pesara 120 kg...mmmm...
    Los caballos son los cv, pero la relación peso/potencia es la que manda.
    09 Jan 2006
    KTM 950 SE
    al lado del TGV
    Whoa... what's all this?
    A very welcome and largely unexpected addition to the ranks of exciting new BMWs. Designed to provide an attractive way into the whole Beemer thing for younger riders, the trio of new bikes consists of the G650Xmoto Street Moto, the Xcountry Scrambler and Xchallenge Hard Enduro. All are based around an upgraded, 53bhpversionof the 652cc Rotax single-cylinder engine seen in the F650 GS (which remains in the range), in a new steel-tube frame with bolt-on alumunium subframe, lightweight cast swingarm and a fuel tank under the seat.
    Claimed weights are low (144-148kg or 317-326lb) and all have chain drive, 45mm upside-down forks and normal brakes: no odd front suspension or belt drive here. Each has its own specific brakes, wheels and suspension set-up to suit the road, multi-purpose and off-road guises.
    Why does it look familiar?
    Ah... you think you recognise the Xmoto Street Moto? If you're thinking Aprilia Pegaso Strada, then well spotted - the new bikes were developed in cahoots with Aprilia, and will be knocked out by their factory in Italy. As well as a clear styling and colour links to the XT660-powered Strada, the Xmoto shares the same 17in cast wheels and Brembo four-pot front brake. The road bike has firmer damping and less suspension travel than the others, sharper geometry thanks to the smaller front rim, and a KTM Duke-style headlight cowl.
    The naked Xcountry is designed to have the dual purpose look and ability of fifties and sixties scramblers, and differs by having 19in front and 17in rear wire wheels with semi-knobbly tyres, softer suspension with a rear ride-height adjuster and a two-pot front brake. And the start Xchallenge Hard Enduro is, as the name clearly suggests, a full-on trail bike with 21in and 18in wheels,long travel, softer forks with different spring rates, and hte fancy air rear shock used on the mighty HP2 enduro. It also wears flexible plastics to cope with spills, has lower overall gearing and a lightweight wave front disc.
    Any optional extras?
    We could fill the mag: there's everything from ABS and pillion footpegs to crash pads, luggage and Akrapovic exhausts.
    Este es el texto que casi no se puede leer.
    otra fotito
    Amortiguador trasero tipo HP2, peso sobre los 148kg. Una buena competidora para la XR650R?
    Última edición por Mr.Thompson; 10-10-2006 a las 14:19
    R 1200 GS Adv.
    En mi casa
    Este chisme no le llega a la XR ni a la altura de la válvula, salvo por el botóncito de arranque.
    Me voy acoplando Avatar de rambo
    12 Jun 2006
    San Juan Alicante
    A mi me gusta bastante,"parece" que la moto tiene calidad,siempre que no se pasen con el precio acertaran,pero si no.......me compro una ktm...
    a mi el motor de la 650 NO ME GUSTA, lo encuentro muy soso y sin caracter.
    habrá que probarla.
    02 Jun 2006
    BMW R850R
    Sevilla, España
    habrá que probarla.
    Estoy contigo, Goliat!
